PSoC 4
I am using CYBL10161-56LQXI for my project with RTC enabled. How to enable alarm repeatition u.e. "Alarm should trigger at given time every weekday i.e. from monday to friday" or any other repeatition rate? I have been through the datasheet and code files but could not figure this out.
Thanks for answers.
Ashutosh
Bob_Marlowe
Expert II
You cannot set multiple different alarms. You will need to handle that in your alarm handler by setting the next alarm time/date.
Bob
Bob_Marlowe
Expert II
You will need the RTC component from system components to maintain time, date and alarms.
Bob
PS: Datasheet for CYBL10x6x shows "Not for new designs"
Thanks Bob. I did use the RTC from the system components in the schematic and enabled the alarm in the customizer. My question is how can I set the alarm in such a way that, alarm occurs every Monday, Tuesday and Wednesday. I tried using masks like this
<code>
RTC_SetAlarmMask(RTC_ALARM_MIN_MASK | RTC_ALARM_HOUR_MASK);
</code>
But, this enables the alarm for every day at given hour and min. I want it to be enabled only for 3 days of the week. Is it possible? if yes, how to do it?
Bob_Marlowe
Expert II
Bob
