PSoC™ 4
hoop4g
50 sign-ins 25 sign-ins 10 replies posted
Dear Team Cypress,
Can CY8C4125PVE-S422 , together with Motor driver, control Stepper Motor through SPI communication for micro-stepping?
Can CY8C4125PVE-S422 and motor driver be used to achieve microstepping control feature with SPI to Stepper Motor?
The datasheet for the part, CY8C4125PVE-S422 ,follows:  https://www.cypress.com/file/429186/download
Thank you for your help.
Sincerely,
Ben
LinglingG_46
Moderator 750 replies posted First comment on KBA 500 replies posted
No.
No.
hoop4g
Hi LinglingG_46,
thank you LinglingG_46 for your reply.  We want to find the Cypress part for the job still.
we are trying to use Cypress part,  CY8C4125PVE-S422 at the moment, in the next design of customers.
Is there any other Cypress part from the same family as CY8C4125PVE-S422, that can do the microstepping control through SPI communication?
If you can share the recommendation, that would be appreciated.
Sincerely,
Ben
LinglingG_46
Now, we don't have the PSoC chip to achieve the function, but you can refer the stepper motor solution in the below linker:
https://www.infineon.com/cms/en/applications/solutions/motor-control-and-drives/stepper-motor/
