Hello!
So I'm in my first year of messing around with a PSoC and have gotten the CY8KIT-042 pioneer kit.
As project I'm trying to get the PSoC the be programmed by the ESP.
I've gotten it to work so it would flash over USB but I honestly have no idea on how to start this project with the ESP.
Any help? Thanks in advance ^.^
Please refer this AppNote : http://www.cypress.com/documentation/application-notes/an84858-psoc-4-programming-using-external-mic...
Vasanth R S
If CY8KIT-042 is connected - you will see KitProg USB-UART (COMxx) in Device Manager.
This means that you have a COM port on the J8 connector.
Tx: PSoC 5LP P12 [7] (on J8)
Rx: PSoC 5LP P12 [6] (on J8)
eg:
Yes I got this to work so that I can flash the board via USB but now I wanna try to get it so it flashes trough the ESP8266 is this possible?
Vasanth R S
