PSoC 4
TyFo_1975986
New Contributor
Right now I have to navigate to the Bootloader.hex and program it to my device, then navigate to my Program.hex and program that to my device for it to work.
Is there a way using PSoC Programmer to program my device with the Bootloader.hex and Program.hex at the same time?
Vasanth
Hi ,
When you program bootloadalbe project to your device (After keeping dependency path for the bootloader correct in bootloadable component) , the program you want and the bootloader will be programmed into the device. You don't have to do it individually. Please go through bootloader and bootloadable projects in the code example section. That will be helpful.
VSRS
