PSoC 4
What is the recommended way to power the PSOC4 efficiently and without disturbing the radio? I want to power it off of a single lithium ion cell. I am currently powering it straight from the cell with a battery cutoff circuit.
If I use a buck regulator, will that create too much noise? Would adding another LDO be pointless?
rola_264706
Honored Contributor II
Nick Check out these documents about power reduction and battery operation.  You might also want to check out the Solar powered modules in the Ble family.
rola_264706
