Powering PSOC4BLE most efficiently for low power
What is the recommended way to power the PSOC4 efficiently and without disturbing the radio? I want to power it off of a single lithium ion cell. I am currently powering it straight from the cell with a battery cutoff circuit.
If I use a buck regulator, will that create too much noise? Would adding another LDO be pointless?
rola_264706
Level 8
Level 8
Nick Check out these documents about power reduction and battery operation.  You might also want to check out the Solar powered modules in the Ble family.
rola_264706
Level 8
Level 8
