PSoC™ 4
MaSa_4211176
New Contributor
Hello - new here so sorry if I am in the wrong place.
I will be porting code from a CY8C4248XXX–BL483 to a CY8C4248XXX–BL583 system.   Physically they look the same.   Are there any revision guides that will explain the differences?
Thanks in advance.
AnkitaS_51
Presently, there is no porting guide available as required
You can find the difference between 483 to 583 part at page#38 of the datasheet available at this link:
https://www.cypress.com/file/416486/download
Basically, 483 part is Bluetooth 4.1 compliant and 583 part is Bluetooth 4.2 compliant.
I created a Code example BLE_Glucose_Meter in PSoC Creator 4.2 for device CY8C4248FNI–BL483, it builded successfully.
Then I changed the MPN using Device selector to CY8C4248FNI–BL583, the project again builded fine.
Thus, I think you can port the code directly.
AnkitaS_51
