Hello Team Cypress,
I am here to ask for a Cypress MCU in order to replace Microchip's ATSAMHA1E15A-B(32-pin QFN)
https://www.microchip.com/en-us/product/ATSAMHA1E15A-B
The MCU part, that we seek, shall
-have the automotive quality.
- be used for the step motor starter application for "active grille shutters"
- be used along with the LIN step motor gate driver from Infineon (see the blocks above).
- support LIN+SPI communication protocol (the MCU will run in LIN slave mode)
- have an equal or smaller packaging size with the products listed above preferably due to PCB size.
- have a relatively good delivery date in terms of logistics.
If you could suggest
specific model with the part number
from the Cypress automotive quality MCU
for the MCU part of the design block,
that would be really appreciated.
Thank you in advance.
Sincerely,
Ben
Automotive General
Hi
One of the recommended part for this will be CY8C4147LQA-S463. Also, I have attached the datasheet for the PSoC 4100S plus device family. You can select the part number as per the memory, temperature tolerance, resources required for the application here.
Ronak
