PSoC4S EXTCLK settings
MiNe_85951
Level 7
Level 7
Distributor - TED (Japan)
50 likes received 500 replies posted 50 solutions authored
I will discuss the contents of the past inquiries once again.
I have heard that the behavior in question has been reproduced.
Have you found this problem?
PSoC4S CY8C4126AXI-S445 EXTCLK settings
As we confirmed, even PSoC4 does not work depending on the series.
PSoC4S has confirmed the operation of changing clock.
However, it does not work with PSoC4S +.
PSoC4S : CY8CKIT-145
PSoC4S+ : CY8CKIT-149
Both of them have the same project contents and input the external clock to P0[6].
Is there any necessary steps to switch clocks?
Ekta_N
750 replies posted First like given 250 solutions authored
Hello Masashi,
Please use the following code for switching clock to EXTCLK in case of PSoC 4100S Plus
#include "project.h"
    CY_SET_REG32((void *)(CYREG_HSIOM_PORT_SEL0), (CYVAL_HSIOM_IO0_SEL_ACT_0 << (6 * 4))); /* HSIOM_IO0_SEL_ACT_0 */
    CY_SET_REG32((void *)(CYREG_GPIO_PRT0_PC), (LED_DM_DIG_HIZ << (6 * 3))); /* High Impedance Digital */
    /* 6 is a pin number, 3 and 4 are bitfield widths */
    CySysClkWriteHfclkDirect(CY_SYS_CLK_HFCLK_EXTCLK);
    for(;;)
        LED_Write(0);
        CyDelay(500);
        LED_Write(1);
        CyDelay(500);
I have attached the sample project below.
Best Regards
Ekta
Ekta_N
Hello Masashi,
    for(;;)
        LED_Write(0);
        CyDelay(500);
        LED_Write(1);
        CyDelay(500);
Best Regards
Ekta
MiNe_85951
Level 7
Level 7
Ekta-san,
Thank you for your response.
Added changes to register settings suggested by you.
Then, it was confirmed that the clock switched normally.
I think that the compile contents set to ECO are different for each device or maybe the version of the boot component.
We hope there is an application note.
Ekta_N
Hello Masashi -San,
This issue will be fixed in the next release of PSoC Creator.
Best Regards
Ekta
MiNe_85951
Level 7
Level 7
Ekta-san,
I understood that it will improve in the next version of PSoC Creator.
I appreciate your support.
