PSoC4500S series : Bias mode of Segment LCD component
MiNe_85951
Level 7
Level 7
Distributor - TED (Japan)
50 likes received 500 replies posted 50 solutions authored
We are considering PSoC4500S as a segment LCD driver.
The specifications required for the segment LCD driver are "COM x8, SEG x32, 1/3 bias".
I confirm for the Segment LCD components of PSoC4S, but 4 com can support 1/3 bias, but 8 com cannot support 1/3 bias.
PSoC4 Segment LCD(SegLCD)  component v1.30 datasheet URL
https://www.cypress.com/file/220341/download
Do you know how to make 1/3 bias compatible with 8 com?
Aashita_R
50 likes received 100 solutions authored 250 replies posted
Hi @MiNe_85951 ,
As per the information shared by you and also as mentioned through the table in the datasheet, I see that there are some limitations with the combination of 8 COM and 1/3 bias use cases. However, I would confirm internally once and post here my response once I get a reasoning from my internal team.
Meanwhile, you can go through the application note here : https://www.cypress.com/documentation/application-notes/an87391-psoc-4-segment-lcd-direct-drive. This AN has pointers to some basic projects which you can check at your end for initial testing. Please add here in case you have any further query.
Aashita
