PSoC 4
RyYo_1406951
Contributor II
When executing the API of InitializeAllBaselines, which value of BaseLine is set?
①RawCount
②RawCount(After executing software filter)
ShanmathiN_06
Hi, as the name suggests it is only the initialization of baselines. If you require the software filters enabled to be executed, pls use UpdateAllBaselines API.
You could refer to CapSense component datasheet for more details.
Shanmathi
ShanmathiN_06
Shanmathi
RyYo_1406951
Contributor II
Shanmathi-san
Thank you for your answer.
