I'm developing an electronic board with CY8C4126AZI-S455. I would use Watchdog to generate an interrupt every 10ms witch will used as tick for a time scheduler.
In past i have used this code https://community.cypress.com/message/145533 for a BLE module but it doesn't work for this microcontroller.
Can someone help me to generate a 10ms interrupt through Watchdog Timer for CY8C4126AZI-S455 microcontroller?
Thanks in advance
Gianluca
Hi GiSe_3918726
You can refer CE210292 which is a WDT code example for your reference. This generates an interrupt every 500ms and can be modified according to your requirement. I am also attaching a sample code that I modified from this CE to generate a 10 ms WDT interrupt event.
Please do try this out and let us know if it meets your requirement.
Hari
Hi GiSe_3918726
Hari
Hi Hari,
your project works!
Thank you very much
Gianluca
