PSoC 4
Hi:
I have a quick and specific question, you know that the CY8CKIT-042-BLE has an FRAM module, the PSoC and this module communicate by I2C, in the component datasheet says that you can establish the communication at FM+ (Fast mode plus 100 Kbps), but when I tray to use this data rate errors seems to appear, I don't know if this is because of my program or maybe hardware limitations of the FRAM module.
I would appreciate any help or advice that you can bring me
Martin
P.S.  I am attaching my probe code.
Bob_Marlowe
Expert II
I would suggest you to enable I2C Byte Mode. I had no problems with that configuration and the FRam.
Bob
