i want pulse capture using timer event (bluetooth Connected State)
pulse time : 1us ~ 500ms
Does the timer event stop by the Bluetooth stack when capturing a pulse?
i use CC2541 TI bluetooth MCU
but CC2541's timer stops by bluetooth stack
CRITICAL_SECTION Events occur periodically
so i use external MCU.
how about PSOC4 BLE?
I want to make a Sensing system similar to 4channel logic analazor. (Resolution : 1us)
After data collection is completed, data is transmitted to Bluetooth
thanks
BLE
Welcome in the forum.
BLE radio and PSoC hardware (timer) are running independently from each other. Short (!) interrupt handler processes as reading some pins or ADC values will not disturb the flow.
I would suggest you to get a CY8CKit-042 BLE-A Pioneer Kit from one of your distributors. Price will be (without tax and customs) ~USD50,
There are many different examples you can access when the kit software is installed, including a quite comfortable IDE named "Creator".
Bob
Bob
thanks Bob
i'll test it
