PSOC4 BLE Module - I2C write buffer not working
JiWa_1379161
5 sign-ins 10 replies posted 5 replies posted
I am trying to write several bytes to an eeprom over I2C. It seems the library has changed because previous code I have done this with no problem using the same module. I just cut and pasted the code and now everything stopped working. The old library version was 3.20, the new is 4.0
If I use the write byte or read byte as shown that works.
    int x;
    buffer[0] = 0xf8;       //node address
    I2C_1_I2CMasterSendStart(I2C_SLAVE_ADDR,0,1000);
    I2C_1_I2CMasterWriteByte(buffer[0],1000);  //data address
    I2C_1_I2CMasterSendRestart(I2C_SLAVE_ADDR,1,1000);
    for (x=0; x<7; x++)
      I2C_1_I2CMasterReadByte(I2C_1_I2C_ACK_DATA,buffer,1000);
      deviceAddress=buffer[0];
    I2C_1_I2CMasterReadByte(I2C_1_I2C_NAK_DATA,buffer,1000);
    I2C_1_I2CMasterSendStop(1000);
If I want to write using a buffer as shown, no data is transferred. I have a I2C sniffer that shows all transactions on the line and all I get is the slave address sent. Nothing else, no data, no ACK, no stop.
  buffer[0]=0x02;//eeprom location for delayTime
  buffer[1]=delayTime>>8;
  buffer[2]=delayTime&0x00ff;
  i2cError = I2C_1_I2CMasterWriteBuf(I2C_SLAVE_ADDR, buffer, 3, I2C_1_I2C_MODE_COMPLETE_XFER);
The i2cError returned = 0;
Problem only occurs with write or read buffers, not write or read bytes.
CyGlobalIntEnable is called before any I2C requests.
Am I missing something?
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
> I would like to know from Cypress why their library isnt working or if it is just a simple command I am missing.
OK, then you are on your own.
> even the code you provided will no longer work as is.
> You need to add an extra value to each function which is a timeout value.
BTW, in the same source file with the above code, I had lower level API onion skins, too,
which you don't have to care, though.
uint32_t i2c_SendStart(uint8_t rw)
    return(I2C_I2CMasterSendStart(i2c_slave_address, (uint32_t)rw, TIMEOUT_MSEC));
uint32_t i2c_SendRestart(uint32_t bitRnW)
    return(I2C_I2CMasterSendRestart(i2c_slave_address, bitRnW, TIMEOUT_MSEC));
uint32_t i2c_SendStop(void)
    return(I2C_I2CMasterSendStop(TIMEOUT_MSEC));
uint8_t  i2c_readByte(uint32_t acknak) /* 6-Mar-2018 acknak added */
    uint8_t data ;
    (void)I2C_I2CMasterReadByte(acknak, &data, TIMEOUT_MSEC) ;  /* ignore error */
    return( data ) ;
uint8_t  i2c_readReg(uint8_t addr)
    uint8_t data ;
    i2c_SendStart(0u) ; /* for write */
    i2c_writeByte(addr) ;
    i2c_SendRestart(0x1u) ; /* for read */
    CyDelay(1) ;
    data = i2c_readByte(I2C_I2C_NAK_DATA) ;
    i2c_SendStop() ;
    return( data ) ;
moto
MotooTanaka
Level 9
Level 9
This may depending on the slave device, but in my sample below
MCU Tester, a Swiss Army Knife for PSoC (CY8CKIT-044 version)
I implemented i2c_readRegs() something like
void i2c_readRegs(uint8_t addr, uint8_t *data, int len)
    int i ;
    for (i = 0 ; i < len-1 ; i++ ) {
        CyDelayUs(i2c_delay) ;
        data = i2c_readByte(I2C_I2C_ACK_DATA) ;
        CyDelayUs(100) ;
    i2c_SendStop() ;
I needed add CyDelayUs(i2_delay) after restart,
not sure if I need it for all bytes, though.
Some device worked with i2c_delay = 30,
but some required more .
So I added delay command which can change "i2c_delay".
moto
Hi Moto
Your way is an alternative. My issue is I have several projects all with the same code using the writeBuffer command. I really dont want to go back to each one and change the code as a work around. I would like to know from Cypress why their library isnt working or if it is just a simple command I am missing.
even the code you provided will no longer work as is. You need to add an extra value to each function which is a timeout value.
MotooTanaka
Level 9
Level 9
    uint8_t data ;
    return( data ) ;
    uint8_t data ;
    CyDelay(1) ;
    i2c_SendStop() ;
    return( data ) ;
moto
