Hi everyone,
I've programmed a PSoC4 Chip with BLE. When i programmed the chip everything works fine and i can connect with CySMART on it.
But when i do an interruption on the P2.7 button of the development kit the BLE device stop emit and i can't connect.
I can share my code, if you can check it ?
i do a lot of things on this code (usb write, I2C read ....)
Thanks !
BLE
Could you please check if you are stopping BLE in Pin interrupt service.
Could you please share your project so that we can check at our end?
P Yugandhar
When i make an interrupt with the button (who permits to increase a counter). The chip is emitting but cannot bu connected. And after it's disappear
Do you have download my project ?
I will create a Customer support case for you please share your project over there. The project which you send here was not opening at my end. It was showing that the archive was in unknown format or damaged.
P Yugandhar.
