Motor driver is activated but couldn't rotate and only vibration is able to hear
In FOC sensorless BLD
JobinT_31
50 solutions authored 25 solutions authored 10 solutions authored
Please confirm if you are using 037 Cypress kit. You can see there is a status LED, which might be blinking. Please check the error status.
You can debug to find this, (usual issues: over current, over voltage).
Can you observe a jerk movement when you try to start the motor, that means the error happening in the orientation stage of start-up.
Jobin
