Regan_Yan
Welcome! 5 questions asked First reply posted
Miniprog3 can only be used as programmer, can't be changed to I2C communication mode.
How to repair it? Thanks.
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Are you using the 5 pin connector of the Miniprog3 to do I2C communication?
What do you see in the Bridge Control panel(assuming you are using this for I2C) GUI? Not in the available port list?
Roy Liu
Regan_Yan
Yes, 5 pin connector.
Failed to enumerate I2C devices when click "List" button.
Roy_Liu
Mostly not an issue with the Miniprog3, but the PSoC that MiniProg3 connecting with, did you try with other PSoC boards/EVK?
Roy Liu
Regan_Yan
This Miniprog3 could program each PSoC normally.
If possible, I can provide this Miniprog3 to your side for testing.
