Community Announcement : Welcome to the NEW Cypress Developer Community.
PSoC 4
XiaoPing_Yang
New Contributor II
Hi Sir,
     Which doctument have the memory map of CY8C4146AZI-S423? The memory map is not in its datasheet.
NoriakiT_91
The PSoC 4100S Architecture Technical Reference Manual (TRM) has the memory map.
https://www.cypress.com/documentation/technical-reference-manuals/psoc-4100s-and-psoc-4100s-plus-pso...
The PSoC 4100S Registers Technical Reference Manual (TRM) has the register address map.
https://www.cypress.com/documentation/technical-reference-manuals/psocr-4100s-plus-psoc-4-registers-...
Noriaki
NoriakiT_91
Noriaki
XiaoPing_Yang
New Contributor II
Hi Noriaki,
    The TRM , describe the 4100s  memory map .  CY8C4146AZI-S423 memory adress may be 0x00000~ 0x 10000 , but cann't find it in any document.
    Thanks .
LinglingG_46
You can open a CY8C4146AZI-S433 project in creator, build it, then open the cm0plsgcc.ld file (if you use the GCC complier) in cy_boot folder.
From the MEMORY, you could find the memory allocation like below:(64k flash, 8K sram)
