Are there ANY drawbacks having mag-sense LX+RX pins configured with the "yellow status"?
- any risks for lower performance?
- how can I see what resources are used up due to the "non optimal" pin config!?
Also,
- what's the logic behind how magsense buttons LX vs RX can be placed.
it seems to be quite strict that a LX/RX pair can't sit on a neighbouring pin
(which is usually what you want when routing)
right now, one coil always needs a wire coming from two separate sides of the part
It is described in Help of PSoC Creator.
The image is excerpted below.
The yellow display is functionally fine.
However, automatic wiring can cause problems.
A common problem is that analog wiring is not possible or it may affect dedicated pins such as SCB.
After building the project, if there are no errors, I think there is no problem.
