DaHu_285096
Level 5
Level 5
10 likes received 250 replies posted 100 replies posted
 I have a low powered application using PSOC4200 powered by 3V battery.
The application has the micro and 2 other ICs on the PCB.
The other 2 ICs combined draw 12uA. Currently I put the micro into deep sleep and all I need is to wake on an interrupt on a Pin state change.
I have measured total current around 60uA, this implies the 4200 is drawing 48uA instead of the 1.3-15uA suggested in the low power guide.
I do have the LVP enabled as I want to know if battery gets low. IIf this is drawing current then I could stop the LVP int before deep sleep and start again on wake.
I have SPI being used when wake and also a timer interrupt that is stopped before putting to deep sleep.
My target is 30uA total for the circuit (around 15-20uA for 4200 would do the trick).
ETRO_SSN583
Level 9
Level 9
Did you try running one of the example projects to see if you could
eliminate the PSOC.
I am sure you have seen these -
http://www.cypress.com/?rID=105694     CE95288 - CapSense Low Power with PSoC 4
http://www.cypress.com/?rID=78797     AN86233 - PSoC® 4 Low-Power Modes and Power Reduction Techniques
Discretes like bulk caps not leaky ? No floating pins configed as inputs ? No loads being driven ?
No pins taken outside rails causing input protection diode current ? No regulator drawing reverse
current in its output ?
Regards, Dana.
