Hello all,
Is it possible to configure the LIN slave node as a passive listener only?
It is because of the situation below: We are going to install a separate system in the car. Actually we don't need LIN, but we need a signal from the master node, which triggers our system (or we will tap the signal somehow else). I also have the LDF file and wonder what happens if I pretend to be a slave node and basically do nothing but wait for the signal. Would this be possible or would I block the already existing node?
Michael
PSoC 4 MCU
Hi @Michael_K ,
Could you let me know which device is being used?
My understanding is that the LIN listener does not intend to send any data on the bus, but wants to receive data. If so, then this should be feasible. LIN slave has to subscribe to the frame-id and not publish anything on the bus.
Nikhil
Hi @Michael_K ,
Nikhil
Hello Nikhil,
we are using a CY8C4146AXI. Thanks for the info. I thought something like that and just wanted to have it confirmed.
I will try it out this week and report back if I remember 🙂
Ragards,
Michael
