AkKa_1244106
First solution authored 10 sign-ins 5 replies posted
We are developing a LIN 2.1 slave device using CY8C4146LQA-S433.
The LIN component datasheet states that it supports 2.2, 2.1 or 2.0.
However, there is no 2.1 choice in the component properties.
Please tell me how to use it with the LIN2.1 specifications.
Ashish
25 likes received 50 solutions authored 100 replies posted
You can just select 2.2 compatibility, as both LIN 2.2 node is  "fully compatible" with 2.1 node. Also, I checked the difference between the two versions in LIN 2.2 spec,  I found there is no significant difference (only spelling correction and clarification).
Kind Regards,
Ashish
Ashish
Kind Regards,
Ashish
Hi Ashish,
Thank you for reply.
I understand from your explanation.
Kanda
