Is the 10bit slave address available on PSoC4?
YoIs_1298666
250 sign-ins 100 replies posted 100 sign-ins
I have a question.
In SCB component of PSoC4, I can not find how to set 10bit slave address on component configuration and API.
Yocchi
RyanZhao
250 sign-ins First question asked 750 replies posted
Hi Yocchi,
PSoC 4 also supports 10-bit address matching for I2C with firmware support.
If a 10-bit slave address is required, you must use software address decoding and provide decode support for the second byte of the 10-bit address in the ISR.
Ryan
RyanZhao
Hi Yocchi,
Ryan
Hello Ryan-san,
Thank you for your reply.
I understood it.
Yocchi
