PSoC 4
I am attempting to install PSOC Creator 4.2 from the Cypress Website, however, the installer stops responding as soon as the License Agreement windows displays. I am running Windows 10. Please help!
I am installing from the link below:
http://www.cypress.com/products/psoc-creator-integrated-design-environment-ide
DheerajK_81
This issue is because of the system environment and there could be many possibilities on why this could be happening.
Please ensure the following pointers:
#1: You are running the installer as Administrator
#2: You are connected to the internet and not through a proxy
#3: You have sufficient memory in your C: drive where the installation directory will be located
#4: You have no other software's running which may be hindering with the installation
#5: You have Anti-Virus and Windows Defender disabled
#6: You do not have the system running on a network domain
#7: You are running the install after complete uninstallation, there maybe certain corrupted files if uninstall was incomplete
Let me know your observations.
Dheeraj
DheerajK_81
Can you please attach a screenshot of the error dialog? It will help us understand your issue better.
Hope your setup follows the minimum requirements for install as shown below:
Additionally, please check for these pointers:
1) Any Anti-Virus software enabled which might be interfering with the install
2) If this isn't a fresh install and you are upgrading from older versions to this, make sure you have uninstalled them correctly
3) Try disabling Windows Defender and then installing
Dheeraj
I believe I have the minimum requirements to install. My computer has a Intel i7 processor with enough space. Attached I have a screenshot of the point where I get stuck.PSOC42_Not_Responding.JPG
I have not heard a response yet. Help would be appreciated.
DheerajK_81
Dheeraj
