Hi Cypress,
I use example files PSoC4_CapSense_Tuner_I2C , It will always show:
Info: gde.M0106: Errors found while loading "D:\project\Tuner_I2C01_C43.cydsn\TopDesign\TopDesign_01.cymacro" file. This file would not be considered in the update process. How can I make it disappear?
Lin
Hi lili_285866,
Sure. Here are the steps to follow -
To exclude the file from the project -
1. In the PSoC Creator Workspace Explorer click on Components tab as shown in the snapshot below. Here you will find the TopDesign_01.cymacro file.
2. Right click on the TopDesign_01.cymacro file and select Delete.
3. Next click on Exclude as shown.
To update the project components -
1. Right click on the project in the Worspace Explorer and select Update Components.
2. In the Component Update Tool window that appears click on Next > Finish.
3. This should update all the components in the project.
Please let me know if you have any further queries.
Thanks and Regards,
Rakshith M B
Rakshith M B
Hi lili_285866,
Can you please let me know if you created the TopDesign_01.cymacro file? If that is the case in which version of PSoC Creator was this created?
I excluded this file from the project and updated the components in the project. After this I was able to build the project successfully. I do not have the right device to test the functionality of the project. I have attached the modified project for your reference. Can you please program the device using this project and let me know if the project is working as expected?
Thanks and Regards,
Rakshith M B
Rakshith M B
Hi Rakshith,
I use PSoC Creator 4.3 find example PSoC4 Capsesne tuner I2C to build project , Can you teach me how to exclude this file from the project?
I use your project compiler is no problem.
Lin
Hi lili_285866,
Thanks and Regards,
Rakshith M B
Rakshith M B
