Panometric
100 sign-ins 100 replies posted 10 solutions authored
In a design where the ECO trim was not correctly set in the fixed stack per ECO Capacitance Trim Values for EZ-BLE™ Modules - KBA218990 , does setting the trim in the application code fix the problem? Or does the trim value get reset when starting the fixed stack bootloader code?
SudheeshK
250 sign-ins First question asked 750 replies posted
The ECO trim value will get reset when the bootloader starts. So, you have to set it from both bootloader and bootloadable projects.
Thanks and Regards,
Sudheesh
SudheeshK
Thanks and Regards,
Sudheesh
