PSoC 4
phs_4630921
New Contributor
I can read the ADC conversion for thermistor voltage in oscilloscope, but the LCD is not displaying the text and numbers.
Vasanth
Did you set up the LCD properly ? Have you been able to display anything on LCD ? Kindly check any code example which uses LCD component to confirm what is going wrong at your end. The following appnote should be helpful.
https://www.cypress.com/documentation/application-notes/an66477-psoc-3-psoc-4-and-psoc-5lp-temperatu...
The code example have LDC interface too. https://www.cypress.com/documentation/code-examples/ce210514-psoc-3-psoc-4-and-psoc-5lp-temperature-...
Vasanth
Vasanth
Vasanth
