I m using a PSoC 7124 BTLE and I cac´t add a single opamp.  This error appears:
Unable to place component "\Opamp_1:cy_psoc4_abuf\". Either the design is bigger than this chip can handle, or the design is over-constrained and there are not enough resources to satisfy the constraints.
I am using few thing of the PSoc, and in the and in the project datasheet is saying that I can use 2 OpAmps.
Any idea,
Thanks in advance,
Aitor
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
Post you project for forum to look at -
“File”                                                             Creator
“Create Workspace Bundle”
If you are using Creator 3.3 There is a Resource Meter tab, upper right
border of Creator that shows resource usage. Also you can, in work space
explorer, for any Creator version, see a table in the results tab, file ending
in *.rpt, a table of resources used and left.
Regards, Dana.
HeLi_263931
Level 8
Level 8
100 solutions authored 50 solutions authored 25 solutions authored
Do you use anything else that my be dopne as OpAmp (PGA, buffer...)? Or do you already use one of the dedicated OpAmp pins on P1 for something else?
