How to using CY8CKIT-041-40XX to program another PSoC4 chip?
I have a CY8CKIT-041-40XX kit and I want to use the on-board Kitprog2 to program an external Psoc4 chip.
I read Kitprog2 user manual on section 5.2.
It says possible but need to remove zero-ohm resistors to disconnect the onboard chip.
So I read  CY8CKIT-041-40XX Kit Guide but I can't find out which zero-ohm should be removed.
My question is how to do it on CY8CKIT-041-40XX kit.
Vasanth
You should be able program another device even without removing the 0 ohm resistor as there are resistors in SWDIO and SWDCLK lines.
Kit schematic is available at <install_directory>\CY8CKIT-041-40XX PSoC 4 S-Series Pioneer Kit\\Hardware\CY8CKIT-041-40XX Schematic.pdf ■ <install_directory>\CY8CKIT-041-40XX PSoC 4 S-S
In that R32 is the resistor you are searching for
VSRS
Hi vsrs,
Thanks for your response.
Do you mean that just connect external chip through J10? No resistor need to be unsolder.
