I use LabVIEW to program PSoC 4 BLE parts. Works fine using the PP_ComLib_Wrapper.dll interface. But I have to have PSoC Programmer installed for it to work. Why?
I grabbed the prog3 driver for the MiniProg3 (that's what we use) and I can install it on a system WITHOUT PSoc Programmer; but the application doesn't work even though the PP_ComLib_Wrapper is there. Those SHOULD be the only two things I need.
What (exactly) prevents the MiniProg3 from working via the DLL interface when it's driver IS installed, but the PSoC Programmer software is NOT? Will I *have* to install PSoC Programmer on all our test machines to make this work? I can't just install the driver and distribute my application with the DLL file?
This is a real issue for me...
BLE
Hi GaSl_4717236,
Unfortunately, you will have to install PSoC Programmer for you to run your application. There is no workaround for that. Please refer to this thread for information regarding this - Re: PP_COM_Wrapper PSoC Example doesnot work on different PSoC Programmer Versions
Thanks and Regards,
Rakshith M B
Rakshith M B
Hi GaSl_4717236,
Thanks and Regards,
Rakshith M B
Rakshith M B
