PSoC 4
I try to generate Client and Central application by PSoC 4 BLE. To save memory usage, I would like to structure BLE profile by client only.
How can I create the structure without Server by Creator v4.1?
Hello Geon-san,
Thanks. I got it by opening your project.
Anyway, when I made new project and set my BLE component as the same as your BLE component, I could not delete Server in Profile tab.
Can I delete the server in my project?
Please let me your steps how you deleted Server setting.
GeonaP_26
Hello Okegawa-san,
As per BLE spec Vol3, Part C, Section 15.2: All LE Central / peripheral devices shall implement a GATT server. Hence, when you start with new BLE component, you will not be able to delete server in profile tab.
BLE component supports Save Configuration / Load Configuration button. User can save the current configuration for use in other designs using Save Configuration button. Use the Load Configuration button to load the previously saved xml Component configuration.
We have a sample project with client only profile created with older BLE component at PSoC-4-BLE/100_Projects_in_100_Days/Day020_BLE_UART at master · cypresssemiconductorco/PSoC-4-BLE · ...​.
Geon
