PSoC 4
masu_1341616
New Contributor II
About CY8CMBR3108S programming
CY8CMBR3108S have some N/A register. When we try to program from host using HEX file.
We can see the value for all of register include N/A register in HEX file.
We will program all of value under the HEX.file.
is it correct?
On the for verification setting data.,
If we read N/A data after above programming, Does it can read same as HEX.data?
TakashiM_61
Only valid bit field and registers are applicable in the device.
Please check these bit field/registers in
MBR3 datasheet
https://www.cypress.com/documentation/datasheets/cy8cmbr3002-cy8cmbr3102-cy8cmbr3106s-cy8cmbr3108-cy...
MBR3 Registers TRM
https://www.cypress.com/documentation/technical-reference-manuals/cy8cmbr3102-cy8cmbr3106s-cy8cmbr31...
And for verification, please check only valid bit fields/registers.
(i.e. you can ignore "N/A".)
TakashiM_61
MBR3 datasheet
MBR3 Registers TRM
masu_1341616
New Contributor II
Sorry for my lack of explanation
My concern is about this documentation.
https://www.cypress.com/file/133376/download
4.5 Step 3 – Program Flash
4.6 Step 4 – Verify Flash
These sample program access to all address using  " *.H " file.
is it correct?
TakashiM_61
I don't still understand your concern and why you are worried.
The register address and data has been specified in hex file.
The data can be modified, but you create CRC accordingly while flashing the device.
could you please refer to the section 5.2.4 of https://www.cypress.com/file/46366/download and explain more detail of your concerns?
