I am currently working with my first HID over GATT project. I am using the sample code for HID Keyboard as the starting point. However, I am unable to understand two things:
1. The 8 bytes of data I send out using CyBle_HidssSendNotification. What do they mean? Where can I find the specification?
2. How do I know when I can send another key? For example, if I want to send the string "Hello" what should I do? I tried sending via subsequent calls but only the first one arrive.
Thank you.
BLE
1)Are you referring to the HID keyboard example? In that case 8 bytes is the standard number of bytes which will be sent to host in case of all standard keyboards. If you want details on what each bytes means , please have a look at "AN58726"(Link:http://www.cypress.com/documentation/application-notes/an58726-usb-hid-intermediate-psoc-3-and-psoc-...) section: 2.1 Data Sent to the Host.
2) If you have a look at the example project , we have added a small timer KEYBOARD_TIMEOUT. Inside SimulateKeyboard() there is condition
if((CyBle_GattGetBusyStatus() == CYBLE_STACK_STATE_FREE) && (--keyboardTimer == 0u))
this will ensure that the next data can be sent.
Hima
Hi Hima, thank you for the information. Will definitely look at the doc. It is great that there is a timeout on the HID example, this means I can simply make a buffer to store the keys I like to send, and store an index to let the keys out in sequence.
