This is my first time using both PSoC4 and PSoC creator so please bear in mind that I am a total beginner!
In my project I am using the two internal OpAmps which are routed to external pins. I made sure to use the pins allocated for the OpAmps. However when I compile I am given a "Failed to route" error.
I am sure I am missing something out. Any pointers in the right direction would be much appreciated.
I have attached the project in question.
Michael.
rola_264706
Level 8
Level 8
I played with your design and it appears that you are running out of resources and that is why you are getting the unable to route analog resources.  I believe that it is the cap-sense component that is causing this issue.  For a fix you could try a bigger device with more resources.
rola_264706
Level 8
Level 8
