PSoC 4
jcsb1994
Contributor
I wanted to buy a QFN PSoC 4100S Plus chip, but the only available on digikey right now is the CY8C4125LQS-423. It is not clear if I can use capsense with this chip, as the datasheet indicates a dash ( - ) on the CSD column, yet digikey says it has a capsense module.
I cannot validate this in the PSoC creator's device selector, as it is not even there. only the -S413 and the -S433 are available.
My question is:
1. Am I going to be able to program this chip using PSoC creator/ PSoC programmer, since I cannot pick the exact chip in the device selector?
2. Can this chip run a CSX capsense module? It is mandatory for my application.
Thanks!!
Bob_Marlowe
Expert II
In Creator 4.4 the device CY8C4125LQS-S423 is shown without capsense capabilities.
Bob
Bob_Marlowe
Expert II
Bob
