False touch - 4 layer design - PCB revision
jobic_1363266
Hey there,
The case is that I'm having False touch on prototype being triggered. Are there problems with my layout? ( Gerber is attached and also board picture )
How frequently does it happens?
Once in a while.
Board details:
Number of layers: 4
Liquid tolerance: NO
layer 1 ( TOP - Sensors) :
  • Hatch pattern 7mil/45mil ( Connected to Ground)
  • Sensor size 10mmx10mm (rounded corners)
  • Backlight leds
layer 2 :
  • Hatch pattern 7mil/70mil (Connected to ground)
  • All sensor tracks
layer 3 :
  • VDD
Layer 4:
  • Components and tracks
  • surrounded by hatched plane ( connected to GND )
Layer 1 ( TOP - Sensors)
Layer 2
Layer 3
Layer 4 (BOTTOM - Components)
Case structure:
Below I show how the PCB and other elements are stacked.
Touch Surface ( Air )
0.75 mm polycarbonate adhesive
2.4mm to 3mm Acrylic
1.4mm PCB
RyanZhao
250 sign-ins First question asked 750 replies posted
Hi Joao,
The description is not very clear for me, and I don't have a CAD tool to open the gerber file.
The KBA about CapSense troubleshooting is FYI.
PSoC® 4 CapSense® Troubleshooting Guide - KBA219217
How about rawcount, baseline waveform in the whole process? If there are more log can be shared with us, please share. for example, rawcount, baseline waveform, PSoC Creator project.
Ryan
RyanZhao
Hi Joao,
Ryan
