Hello everybody,
I have a short question bout the PSoC 4: Is it possible to extend the flash ROM, so that the program is not started form the internal flash as in the picture below but from a EEPROM from an IC?
The background is that I am working with the PSoC 4 Pioniee Kit CY8CKIT-042 and I have not enough memory for my application and cannot compile it. I would like to expand the memory with an EEPROM with 64 kbyte for example.
Best Regards
Michael
ispn:39611:1:0
l1:314:1:0
PSoC4MCU
- Flash ROM
Hi @Michael_K ,
The feature which you are referring is not possible with PSOC 4, you can refer to the PSOC 6 datasheet which I have shared in my previous response.
Hi @Michael_K ,
>>This feature is not supported in PSOC 4.
You can refer to the PSOC 6 datasheet which supports this feature.
Hello Alakananda,
thank you for your reply.
Is the feature not supported by PSoC 4 in general or only for the EEPROM with I2C?
I may have chosen the IC unhappily, as I was looking for one with I2C. But there are Flash ICs with SPI (without Q) and SPI is also supported by the PSoC 4. I found the application note AN68272 and it describes the principle of the bootloader. If I understood it right, I can use the bootloader to flash the program over a host like a PC via UART or another interface (like an Arduino). Is there a possibility like in the picture below which I have customized from the AN, that the bootloader writes the application to the external flash and reads the program from it?
Best Regards
Michael
Hi @Michael_K ,
