PSoC 4
MiMo_4142486
New Contributor
Hi, how can the example code MagSense_With_Feedback_LEDs be edited to include Encoder Dial sensing on the PSOC4 MagSense Eval Board CY8CKIT-148? If not possible, how can the Eval Board hardware be changed to test encoder feature. Thank you.
ShanmathiN_06
Hi Mikael,
Cypress is currently developing a rotary encoder dial sensing on an inducting sensing based kit with PSoC 4700 S.
A code example is also being developed to implement rotary encoder. We are currently working on this request and it will be available on web ASAP.
Shanmathi
ShanmathiN_06
Hi Mikael,
Shanmathi
