PSoC 4
By bidirectional I mean MOSI and MISO in the same line, often times labeled  as SDA.    Looking at the datasheet, there is no indication of it.
Tony
Looking in the component catalog:
You will need to use a different component, like the "SPI Master Bidirectional mode Macro" component, or the "SPI Slave Bidirectional mode Macro"
That is what I suspected.   Thank you.
You're welcome;
Just as an fyi, the different "components" are merely different analog configurations that implement functionality for use by your application. So, if you are wanting the functionality of a specific component combined with more functionality or another component, you can possibly achieve it by digging deeper into the verilog/analog domain and modifying/creating your own component that does what you want.
