PSoC 4
user_1881301
New Contributor II
where in the component catalog do I find the output pin type they are using for the OutputPinSW.
If I take a Digital Output Pin I can't find out how to configure it / connect it.
Viggo
Bob_Marlowe
Expert II
Place the pin onto the topdesign, right click on it and select "Configure..." (or double click, that does the same). Open and read the pins datasheet to get acquainted to its capabilities. When "HW connection" is checked, you may connect the pin to any signal using the "Wire" tool (called by entering a "W". There are some videos showing how to connect components.
Bob
Bob_Marlowe
Expert II
Bob
