PSoC 4
I'm working on a project with a CYBLE-012011-00  module and i'm facing an issue. At start up everything works fine but if I let the module advertising without connecting to it, after some time (approximatly 10 mins) it stops advertising and it's not visible anymore in the CySmart app.
As soon as I restart it, it reappear.
Do you have any ideas about this behavior ?
I would assume the advertisment is timing out after 10 minutes 🙂
But without seeing the project settings, no way to verify
rola_264706
Honored Contributor II
Please post your code so we can check the settings. Click on File in Psoc Creator and then select Create WorkSpace Bundle and then attach that file to a post by clicking on Add Attachments.
Yes that was exactly that !
Thank you 🙂
