I've iterated several hardware designs but everything I try leads to a code 43 error. I'm using osh park to manufacture the boards. Using Saturn PCB design I've calculated the impedance width of 45 mil. I've included my design files. What do I need to change to get it to work appropriately?
The only time I've had any success is when I do not copper fill the entire board and route the traces without any tvs, resistors, or capactors attached. Yet without the tvs, its functionality lasted only a couple of hours before it was no longer functional. Thanks for the help.
EmHo_296241
10 solutions authored 50 replies posted 25 replies posted
Hey,
Please check kit design file of CY8CKIT-046. This should be helpful . You may compare your schematic with this.  http://www.cypress.com/file/341621/download
