Problem Statement:
Debugger crashing when putting breakpoint in many functions in retarget.c i.e. in _sys_open.
Message on output window while debugging:
~"/home/build/work/GCC-4-8-build/src/gdb/gdb/linespec.c:2445: internal-error: decode_line_full: Assertion `state->canonical_names.suffix != NULL' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? "
~"/home/build/work/GCC-4-8-build/src/gdb/gdb/linespec.c:2445: internal-error: decode_line_full: Assertion `state->canonical_names.suffix != NULL' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? "
Error: dbg.M0015: Debugger exited unexpectedly during run. Encountered error (GDB encountered an error and had to close. See output window for more information. See output window for more information.)
Warning: prj.M0014:
You asked this application to remove "Generated_Source" and its contents from "Design01". Do you want to permanently delete "Generated_Source" and its contents from disk?
Click Yes to permanently delete "Generated_Source" and its contents from disk and remove it from "Design01".
Click No to just remove "Generated_Source" and its contents from "Design01".
YES
PFA project for reproducing the issue.
Still an issue, but no answer to post from long time. Please figure out issue in your IDE. Other IDE are not complaining for breakpoint in retarget.c file.
