PSoC™ 4
KaGr_4461396
New Contributor
I am using a bipolar stepper motor (1528-1062-ND)  and controlling it by an H-bridge (296-36156-5-ND). I was wondering if anybody used a stepper motor and H-bridge combination and had some code or a diagram block. I am using this for class and if anyone has any links or anything to help thank you in advance!
KaGr_4461396
New Contributor
how is this the wrong forum? it is for code?
Vasanth
Hi Kamille,
Community code example is the area for Cypress Community members to share code examples. Kindly make sure that you are using the right space to post your questions as that will get the right attention from the other community members. Meanwhile I will move this thread to the right area.
Vasanth
