I downloaded the capsense one button example from here
I tried to open it with PSoC Creator 3.3 CP2 (3.3.0.7343)
But I am getting following message:
Unable to open the project ".\CE210291_CapSense_P4_One_Button.cydsn\CE210291_CapSense_P4_One_Button.cyprj": Requested value 'CortexM0p' was not found.
Is it possible to open this example?
Br, Ville
BLE
Hi Bob, Thanks for your answer.
I updated the PSoC Creator to version 3.3 CP3 (3.3.0.9604) and example opens now correctly.
When following the instructions on CE210291.pdf
and trying to enable the tuner by setting the macro TUNER_UPDATE_ENABLE to 1 in the main.c file. Following error comes on compiling:Build error: 'CapSense_TU_STS_RESTART_DONE' undeclared (first use in this function)
Seemed like example was missing declaration for "CapSense_TU_STS_RESTART_DONE" variable. I created such a variable and example is now running.
I successfully opened the project in both Creator 3.3 and 4.0. Did you expand the .zip into a new folder?
Bob
Hi Ville.:
You are right. It Seems the example was missing declaration for "CapSense_TU_STS_RESTART_DONE" variable.
I checked CE210488 and CE210291 project.
CE210488:
you can find " if(CapSense_STATUS_RESTART_DONE == CapSense_RunTuner())" in main.c. It use CapSense_STATUS_RESTART_DONE . it's declared in " CapSense_Tuner.h"
CE210291:
you can find " if(CapSense_TU_STS_RESTART_DONE== CapSense_RunTuner())" in main.c. It's different from CE210488.
summary:
I think you can use "CapSense_STATUS_RESTART_DONE'' to replace "CapSense_TU_STS_RESTART_DONE"
