Hi !
Please help to start PWM with unconfigured mode. If I configure it as Timer/Counter it`s work but when I change it to unconfigured TCPWM and use API to configure and start it`s not work. What a point ?
Yor call to PWM_Start() API will overwrite your previous settings. Use at the very first call PWM_Init() which will not start the component but will do (as the name says) the initialization. Then perform your settings and at last call PWM_Enable().
Bob
Bob
Thanks !
