Community Announcement : Welcome to the NEW Cypress Developer Community.
PSoC 4
I'm a newbie for  embedded system, So i have a question to ask in the community.
First of all, i already follow the instruction in the quick start guide document. And my problem is
1. I'm already compile the example program on the board. But the motor doesn't generate any speed.
2. After i have compile program the LED on 042 are turn off. But before compile the LED are blinking in green color
PS.I have try 1 week to make it complete but it not TT
rola_264706
Honored Contributor II
Please post your code by clicking on file and then Press Create workspace bundle select minimal and post the file to a new comment.
rola_264706
which program are you using on the 037 board examples?
I'm using Sensored BLDC motor control Program.
rola_264706
What version of Psoc Creator are you using? Also if you are using PSoc Creator 4.1 then you need to update the components. Also change the void main to int main in the main.c program.
Yeah i'm using PSoc 4.1, but l already debugging from void to int.
rola_264706
Did you press SW1 to reset the board and then did you press SW2 for the board to function.  One other input I assume you have the board motor and power connected correctly.
Yepp, i already reset on SW 1 and start on SW 2, by the way now when i hold SW 1, SW2 stop blinking  and when i release SW 1, sw2 are blinking.
rola_264706
Please post your code by Pressing File and then select Create work Space bundle and select minimal and then attach the file to a new comment.
