I'm working with the cy5677 BLE dongle to connect the PC with BLE 4.2 device (Extended packet support).
I noticed that it cypress website the only SDK available to work with the dongle is written in C#.
This is limiting as my software stack is written in c++, so I need to add CLR support and do some marshaling (performance degradation)
I believe this C# SDK is wrapping native c++ code.
Is there an API to use this BLE dongle with c++ only (no CLR)?
Eran
BLE
Hi Eran,
We have only C# APIs are available for CySmart PC to communicate with BLE dongle as you can see the API reference guide from below link:
http://www.cypress.com/documentation/software-and-drivers/cysmart-bluetooth-le-test-and-debug-tool
Anjana
Hi Eran,
Anjana
Well, that requires whoever wants to use your API to have CLR support in all projects.
