Hello All,
I am a CY8CKIT-043 user trying to work my way through my first application.
A couple weeks ago I posed some questions using the kit's UART function and within a day or so I was back on track, so I am hopeful that my current quandry is something that is easily fixed (i.e. some kind person will point me at an obvious solution I've overlooked.)
Here is my situation: Using the PSOC Creator 3.3 application I have modified the kit's "breathing led" application to make use of the UART function to send strings from the kit to a Putty application. That is working okay now making use of sprintf to fill buffers and then "printing" them using the UART_1_UartPutString() function included in the creator application.
Now I am trying to go in the opposite direction. I'd like to be able to do a 'scanf' response and capture either an integer, float or string value from the UART. I've experimented with scanf which seems to be implemented in the creator but I can't make it work. Essentially I'd like to be able to echo a string back to the user in putty and have them respond, for example "how many iterations?" to which the user responds with an integer.
I realize I could do the getchar() route, capture every byte, convert the ascii to an integer, etc. etc. but I guess I'm just lazy. I'd prefer to not to have to go to this level of effort unless I really have to.
As I've already said, I could very well be missing something. I've searched the net and browsed forums and looked at the reference manuals I've found and I come up empty. Has anyone solved this problem before?
Rich
ispn:39613:1:0
l1:314:1:0
I had a similar request some days ago. Contacted Cypress and got as answer: Newlib nano does not support scanf() functions.
Workaround:
- Do it yourself
- Not using newlib nano which will result in quite more fram usage
- Using atoi() and atof()
Bob
Thanks Bob,
I was afraid that was the case but I had to ask. I guess I'll just need to resuscitate that part of my brain - it has been long unused thanks to higher level languages. You're right though, although primitive, there are still ways to get it accomplished. Thanks for the input.
Rich
